Hey 70. Lots of stuff done to that rig for sure.
First thing I would do is measure the distance between the front bumpstop (if it's still got stock beehive shaped bumpstops that is) and a frame rail. Anything over 7" (edit: corrected from my previous statement) is the amount of lift you have currently. From there we can better address how far down you have to go.
FYI, that 9" is stock, so they can't make you go below that. How much is allowed in your area?
Did they mention the steering rode ends? They look to be of smaller size than the more desirable ones, and are obviously not stainless steel either. As the extensive rust will show. I'd consider replacing them with new ones, just out of hand, but I suppose it's better to just do a quick test to see if they're loose at all first. If they're still tight, then there's not much reason to change them out.
If they're loose, see if you can find some more robust looking versions. If available to fit into your tie-rod tubes.
Looks like you might have our variable rate coils up front there, but they're already looking a bit compressed. If that's the case, even if they're 5.5" coils, you might not have that amount of lift anymore. Hence the bumpstop measurement.
Good luck. Let us know what you find. Hopefully you won't have to go too far down. But at least the springs are easy to replace if you end up having to go way down, then want to go back up afterwards.
Oh, and did you get any of the old stock parts with your purchase? Things like pitman arms and shorter shocks might come in handy and help you not spend so much to lower your rig.
