Install problem Warn Premium Locking Hubs
dsg40th
Southern Maine
Went to install Warn Premium Locking hubs on my High Pinion Dana 44 that I'm swapping in and discovered that The locking hub body bottoms out on the end of the spindle preventing the snap ring groove on the axle stub shaft to be visible let alone install the snap ring. I have tried pushing and prying the stub shaft through from the back to be able to install the snap ring but it's not happening.
Second issue is because the hub body bottomed out on the end of the spindle when I installed the cap / Dial assembly onto the hub body with just the outer retaining ring in place the cap assemby does not seat tight up to the main bearing hub. Looks like the spindle is about 1/8" too long holding the whole Warn locking hub assemby about an 1/8" outward too far.
Any one else have this issue??? I've been doing this stuff for a long time but this is the first time I've seen this issue. My next move will be to remove the spindles and grind them down an 1/8" just thought I'd ask before going that route.
JWMcCrary
You don't need the snap ring on the stub shaft, the ones I'm running don't even have the grove for it. Just push the splined part of the hub in and use the large outer snap ring, screw the outer portion of the hub on and be done
savage
Bronco Nut
Renton
x-2 on The warn premium hubs that I put on my 97 ford f-250,the snap ring on the axle end didn't fit ,my instructions said it my not work,but you don't need it.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
True that you don't need the snap ring, but he points out that when the outer cap is installed, it's still 1/8" away from sitting flush with the hub, which certainly isn't correct.
Both sides do the same thing?
dsg40th
dsg40th
Southern Maine
In this case it looks like if I grind / shorten the spindle down about 1/8" I could install the stub shaft snap ring and have the chrome locking hub cap and dial assembly sit flush with the bearing hub as it should. It appears the o-ring is in enough to make a decent seal as it is but it just don't look right with the gap that's there now.
dsg40th
dsg40th
Southern Maine
Other than the right side being shortend 6" it's an all stock 1979 F150 / Bronco Dana 44 with no mixed and matched parts other than the right side inner shaft but I'm having the same issue on both sides with the Warn hubs.
dsg40th
dsg40th
Southern Maine
I read your thread. I agree the small stub shaft snap ring can technically be left out and not used but my concern is with excessive shaft walking causing the stub shaft dust seal and needle bearing seal to not do their job properly of keeping water and crap from getting into the back side inside diameter of the spindle and destroying the stub shaft needle bearing or worse geting into the locking hub assembly and wheel bearings.
I have enough threads beyond the second wheel bearing lock nut on the spindle to "shave" some material off, so I guess I'll give that a shot when I get the chance to see if can get the snap ring on the stub everything else to fit up nice to the bearing hub.
xcntrk
NOVA
For what it's worth, I've wheeled the heck out of mine in this configuration (only using the large outer ring) and haven't had any issues with the lock-out. But hey if you can get the small snap ring to fit, all the better!
dsg40th
dsg40th
Southern Maine
They are Warn Premium #20990 that fit pretty much all Ford F150 \ Bronco since the beginning of time.
I found a second issue aside from the hub not being able to go in far enough, the snap ring groove on the stub shaft is about a 1/2 inch in from the end of the shaft and from what I read unless your running a stock Ford or Spicer locking hub you can't run the snap ring unless you machine a second groove about 1/4" from the end of the shaft. I've never run into either of these issues ever before but then again I mostly always was doing Dana 60 swaps into full size F150's and Bronco's.
Frustration tells me I should have stuck to jamming a Couple of Dana 60's under it. Lol
dsg40th
dsg40th
Southern Maine
I also borrowed a set of Mile Marker locking hubs and they have a much thinner profile (weaker) than the Warn premium hubs do and they fit very nicely and properly, other than still not being able to install the stub shaft snap ring due to the groove location.
