Installation of weather stripping for door..
TonyMontana
Central
folks, how in the hell do you install new stripping on the floor and still have the door able to fully shut without it sticking out 1 to 2 inches. And also, not having to slam it so hard?
should it be trimmed down? what are my options. TIA
C
gmurrell
i just did this and there was some door adjustment needed. i also snapped a couple hinge bolts in the process so be prepared for that. be patient and use a ton of liquid wrench. there are posts that cover door hinge removal/adjustment that can probably explain it better than i could but i will give it a quit rundown.
support the door with a jack, loosen the bolts a bit (you shouldnt have to actually remove the bolts for this and definitely dont remove them all at once or you will lose the backing plate), tap on them with a soft mallet or with hammer and a piece of wood. once the backing plate is loose (the door will shift when this happens) you can adjust it out (at least thats what i needed to do) and it will close easier. good luck!
Justafordguy
Get the Metro Supersoft seals. They will be a little hard to close for a few days but after that they will close nice.
