NV3550 Installation Question
mnido
I am putting my Bronco back together again after my 331 Stroker went south. My new install is a Blueprint 347. I thought I recalled there was a bearing that went into the flywheel which matched up to the output shaft on the NV3550. However there isn’t a bearing in my flywheel which I had resurfaced. Is there such a bearing ? And if so where can I purchase? Thank you !
If the snout of the input shaft is in perfect condition (new transmission) then roller is fine.
If the snout is less than perfect, has wear, the bronze bushing is the better choice.
