jhunte17
I started installing the chevy disc brake conversion on my bronco last night. I ran into a problem when I tried to install the 4x4 collar that splines to the inside of the hub. It would not slide in and out properly. I could get it in with persuasion (ie lfh) but it would not slide back out. Spent 30 minutes working it out with a couple of screwdrivers. Put the same collar in the other hub on the bench and it seemed to work fine. Got the second hub/rotor installed and the same thing though not quite as bad.
Any thoughts? Any body run into this before and have a solution?
Thanks.
Thanks.
