I received my replacement 351w engine from ATK, the only thing returned off the old engine was the intake manifold they told me. Problem with the old engine was a stuck valve in the #2 cylinder and the bent pushrod for that valve for a 0 compression. Engine had 18 miles and 1.5 hrs of run time. I will be checking the torque on the valves and intake, installing the engine and associated things the were removed when it was taken out. I'll mark the distributor, priming the oil (using break-in oil) checking the compression for each cylinder. Just looking for any tips on what I may have missed or need to do after it is running. Little gun shy!
