Installing replacement leaf spring hangars question
Jeremy0201
Tucson
Hello, I have extreme shearing to the front perch of the rear leaf spring hangar. I bought replacements that were cut from another frame. My question is when I cut mine away can I i keep the part that connects to the under portion of the frame by just cutting the rivets. My thought is that I could put a bolt through where the rivets were so everything would line up easy for welding the upper portion back in place. I worry that I would incorrectly mount them or mount them unevenly.. See my photos, any thoughts or suggestions are helpful, I also have the replacement metal eyelets that you can drill out the existing sheared part and weld in the eyelet. I feel mine are too far gone for that type of repair. The whole nut was coming through the sheared part on the pass side.
Jeremy0201
Jeremy0201
Tucson
Another photo
Another photo it only lets me do one at a time
Jeremy0201
Jeremy0201
Tucson
Jeremy0201
Jeremy0201
Tucson
Another photo
Another photo it only lets me do one at a time what's up with that?
Jeremy0201
Jeremy0201
Tucson
Thanks for all the overwhelming support I guess I'll figure it out on my own. Good thing I'm a contributor.
surfer-b
Calm down, you will get responses, but not very good ones with that attitude.
Now, as for the hangers if I understand you correct, yes you should be able to just grind the rivets off of the old ones, use the holes for alignment and weld on the new as long as the new ones are the same dimensions.
Jeremy0201
Jeremy0201
Tucson
Thanks for your response. I really don't want to make any mistakes. I posted three days ago and I'm still very calm. I'm ready to start grinding and I'm running out of days off. Thanks again. I just thought more people would have a recommendation whether or not to cut the rivets.
surfer-b
Yeah I would just grind the heads off the rivets, drive them out with a punch, and place the new ones on with some alignments bolts like you described then weld away. Just be sure and tack in diff places to keep them from twisting outta place before welding all the way.
