MyOriginal66
- Aug 11, 2009
- 2,071
I had new perches welded on and when installing the rear end I had to push the passenger leaf over a half inch or so to line up with the perch. Is that normal or did the shop weld the perches on at the wrong spot? Also, the u bolts aren't centered in the upper plate the same on the right spring as the left.
