Insulating Firewall Questions
gnsteam
Lincoln NE
When insulating the firewall. With regards to the items mounted to the firewall. Such as brake, e-brake and gas pedal brackets. Do you just pinch the insulation between the bracket and firewall? Or insulated around the brackets with nothing between? How was it installed from the factory? Tear down was so long ago I can't remember how it was at that time.
bigmuddy
Marthasville Missouri
From the factory it appeared as the insulation went on and then everything was installed, essentially trapping the insulation behind the brake lever for instance.
