Yep, nothing exotic. If you do go with the WH set, I thought we only had full engine sets and not the intake only set? Maybe I missed that memo (again!) if we have them.
The only difference in our sets is the type of head and what type of valve cover used. If you have aluminum valve covers you use the "cast" bolt kit which has longer valve cover bolts.
The head style is up to you. Some like the indented look (I do) which is more similar to the factory original stuff, but others prefer the flat top hex bolts so they don't collect stuff.
But the sizes and strengths remain the same.
As said, intake bolts can be had locally usually. If you don't have your original bolts to use, someone here will have one apart I'm sure and can get you the lengths. Hopefully. But the diameter is probably 5/16" or such. But wait for confirmation!
And definitely go by Edelbrock's torque specs. Probably available on their website I would hope.
Good luck.
