I grabbed one of those GM car rear view mirrors with little lights in the bottom of it.
Excellent for light at/on the dash. These little lights can be controlled by little buttons on the front of the mirror but I leave them on because it is wired through my headlight/dome light switch on the dash. Mine came from the last hurrah of gm station wagons.
For the roof area light I use those magnetic led lights you can get at the parts store counter.
I still don't have a headliner. I stick them to the roof cross braces. Even the biggest bumps don't knock them off. You reach up and hit the button and it is super bright. I have two, one at the front cross braces, and one at the rear cross braces for the back seat. Definitely only need one though, ie, bright as hell. But I love them.
And if you need light outside real quick you just pop them off and do your thing then stick them back up when done.
Good little magnets in them.
Darn bright lights.
Real cheap.
Since they are LEDs and barely ever get used the batteries last a really long time. Like years....
Best solution I have ever had for it.
If you have a head liner you could stick them to a flat spot on your roll bar/cage I guess. They have foldable little hooks too.
They are a super quick and easy fix that has worked out better for me than I could have expected.
