Schematic showing windshield with interior light
svobronco
Does anyone have a schematic that shows the windshield mounted interior light wiring? None of the ones I have show it.
I'm putting in a Wild Horses dual wiper motor kit and plan on reusing the factory wiper wiring and interior light wiring to run it. My windshield frame is welded shut and I don't think I can pull new wires thru the frame. The 4 wires on the motor and the hot and ground on the light should do the trick. I just don't know where they go.
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
This is 75-77
svobronco
svobronco
Thanks Oldtimer! You don't happen to know where the negative wire for the dome light terminates, do you?
Oldtimer
Sunnyvale, CA
No, I have vacuum wipers, so no stock electrical wiper harness in windshield frame.
WAG for the dome light harness ground would be on kick panel near parking brake pedal?
Follow harness where it comes thru cowl, behind dash.
Edit: See comment in below post.
Viperwolf1
electron whisperer
It just bolts to the back of the windshield frame. Doesn't go through the wire channel.
svobronco
svobronco
That's what I would have assumed. The 4 existing wires from the wipers and the 1 +12V wire should be just enough for the new motors. Now I just have to climb under the dash and get it done. Not very easy anymore, unfortunately.
