Is this "normal" play/movement
FORD*DIEHARD
Just replaced the entire tie rod/ends as well as the drag link. After installing noticed this movement and wanted to see if this is normal or what needs to be done to fix.
Also just confirming the tie rod bar and drag link are angled the correct way. Last time I was told the drag link zerk fitting was pointed too low/straight and should be pointed up towards the radiator.
Thank you in advance for your time/help,
Sonny
FORD*DIEHARD
FORD*DIEHARD
It will not let me attach the video. Am undoing something wrong?
PNW
Videos typically need to be under 20 sec or so... Try shortening it and making it two videos???
FORD*DIEHARD
FORD*DIEHARD
The clip is only 11 sec, I tried cutting to 09 sec still didnt work so I cut it again to 05 sec and after it tried uploading it said "the uploaded file was not a video as expected " .
Can I email or text it to someone to see if they are able to post it? I'm sure its "OPERATOR ERROR " .
How about the angle of the zerk fitting on the drag link, does that look right?
Looking forward to the video. But otherwise, your drag link angle looks decent-ish.
It could actually go back a little lower, believe it or not, but it’s not bad the way it is.
How is the steering stabilizer attached to the link? Have another picture of it, showing that end of things where the drag like meets the Pitman Arm?
PNW
That bites... might try YouTube or ask Jon what's up.
FORD*DIEHARD
FORD*DIEHARD
So the drag link zerk fitting should be angled (lower-down) or higher- up).
Do these pictures help?
Thanks for the better angle shots.
I’d say it’s almost lined up perfectly to the point where you don’t have to move it. But if you happen to have all those adjuster sleeves loose at some point for doing other work, you could point the Zerk fitting a little further down/forward.
But it’s literally just a few degrees and probably not a critical change.
One reason to change the angle that comes up sometimes, is if the track bar and drag link are not parallel between their mounting points.
If they’re off just slightly, a small tweak to that angle can improve things.
Your parallelism also looks pretty good, but you’re right there and can take an actual measurement, rather then just seeing a picture.
With a tape measure or even just a length of something the right size, note how far the upper pivot point of the track bar is to the upper pivot point (center of the ball basically) of the upper drag link at the Pitman Arm.
Do the same thing at the lower track bar end, comparing it to the center pivot point of the lower drag link and.
If they are close enough, they’re close enough.
