You need to find a shop that you like, drop it off and have them build what you want, or buy one thats done like you want.
I know guys use the ac bracket with the explorer front dress but it might require some vintage air parts to go with it. Probably an aftermarket fuel pump. EB brake set up whether vaccuum or hydroboost. Hydro is a little smaller and better braking. Power steering pump and bracket from explorer will work but will require proper hoses to mate it to whatever ps box you run. Personally I would do the saginaw pump upgrade especially if you go hydroboost or have 33s or bigger tires. I would upgrade from the explorer t-case. Theres an adapter for the explorer trans to the dana 20. I think an atlas mates right up. A 205 case might bolt up but requires more fab worktop instal it. Double check that transfer case info. I'm not 100% on that info but been reading up a little for if I swap mine to an explorer auto trans. The nice thing about getting the entire explorer is you won't forget any plugs, wiring, bolts or brackets at the junkyard.
You can use ANYTHING. You just have to CHOOSE what you want the truck to do when it's finished. Some donors are better for certain things, but we could go on for years. It's all moot until you start deciding what YOU WANT.Can i use...?
Somebody correct me if I'm wrong but the 96 explorer heads play better with most bronco exhaust manifolds or headers due to spark plug angle but the 98 and up efi parts are better. The other explorer heads need the bronco hut headers or possibly a set from bc to get to the spark plugs easier.ive never actually done the swap so somebody with the experience chime in .I've just been reading up incase I swap my 351 to efi.
the gt40 heads require special headers. they are spendy
I think you are stressing too much. This thread includes most of what you to achieve what you are trying to do.
first, forget the engine you, just sell it.
second, find a 4wd v8 explorer 1998 to 2000 may work best. make sure it runs, drives, and has a solid drive train
third. remove engine, trans, computer and engine/trans wire harness.
4rth, install engine and trans into your bronco
5th send computer and harness to efi guy and have him modify harness for your bronco
6th install computer and harness into your bronco
7th, you will need a trans adapter from the explorer trans(4r70w) to the dana 20 you already have. it comes with directions. can be purchased from any bronco vendor site on here.
8th, you may need to modify your drive shares because the transfer case will be slightly back from where it is now, you will also need a lokar shifter adapter.
you will also need the fuel pump out of the explorer and modify for your tank, or better yet, buy a 23 gallon tank with efi oump already in it.
this is 90 percent of the job.
if others have stuff to add or comments, please use 1a or 2a under the according line for additional steps.
or ship it to me and I will do the swap over the fall and winter.
