chuzie
- Jul 21, 2006
- 2,761
Swapped my J for a T shift in a pinch. Running an ZF atlas adapter to my 4R.
Anyway, went to clock it and discovered the T ran into interference and had to hang lower than the J. I didn't see anything obvious in terms of differences although it was a brief cursory observation. There must be a physical difference in the cases on the driver side.
Moving forward to rebuild my J, all 3 low gears are chewed up and the forks are worn causing disengagement of high speed gears (output shaft is fine) . What can be transferred from the T to the J in an effort to avoid purchasing replacement parts?
Sourcing a rear slider gear has proven difficult for the J.
Sent from my SM-G950U1 using Tapatalk
