mattyq17
- Jul 11, 2007
- 1,597
I was having some issues with my engine, it would run fine until warmed up and once the choke opened it would die. Looked for vacuum leaks, didn’t find any, took the top off the edelbrock and it was pretty dirty and had some gelled up fuel I am assuming. Cleaned it up and all was well. This was two weeks ago, I haven’t driven the bronco since then and decided to pull the carb and give it a good cleaning/rebuild this time. Fuel has been sitting in the carb for those two weeks and has jelled up again. Should I add some fuel stabilizer to to the tank, 11 gallons in it roughly, or drain it, pull it, and clean out the tank? I think I know the answer but am hoping that the fuel stabilizer would do the trick. Thanks
