EDIT: I wanted to mention that before ordering these seals I called Wild Horses and talked to them. They told me that they tested many seals and the ones they sell seemed to be the best they could find. And if not happy I can return them.
So, these are a little better than what I bought from TBP, but I am still not totally satisfied. I'm going to see if the doors close better over time.
I followed the Wild Horses install video to the T.
Results-
Before install both my doors were closing with no gaps. Of course with no seals they closed easily.
Passenger side. Seal installed, and immediately as I eased the door closed I knew that it wasn't going to be great. You feel resistance with the door about four inches from closing. If you just push the door closed it doesn't latch tight. So, I had to slam it. It closes fully, but I have close to a quarter inch near the back bottom edge of the door jutting out. That sucks.
Drivers side. Same deal. I have to slam it pretty hard to latch fully. And the rear bottom edge is jutting out a good 1/4". Not what I was hoping for.
I played around with door adjustment, though remember the doors looked fine before the seal install. I got the passenger door to close a little tighter after moving the door latch (at the rear door post) in as far as I could. But I am really closing the door hard.
I can't seem to get the drivers door better with adjusting.
I slammed both doors and walked back to the house. I'll leave the Bronco in the workshop overnight and see if things are better tomorrow. Maybe they will squish in some. It is raining anyway, so the Bronco can't come out to play.
I sure wish the results had been better. It is a lot of time installing these things. This is the second attempt (first tried some from TBP and they sucked worse). I do want to keep the cold air outside, so I guess I'll leave these in place, though not liking my doors jutting out at the bottom.
I took some pics. I'll post them later when I get time to download off the camera. Too lazy right now.
Results-
