- Nov 3, 2003
- 48,370
Im also worried about the to short neck on the tank, seems about 1-1.5 inches shorter than other versions, I hope the piece I have fits as well.
It does seem short, but has never been an issue with the hose sealing to it as far as I know. Has anyone reported it being an issue and I was just not paying attention?
As for the too-short filler hose that was mentioned however, definitely measure it up and compare to what the others with that issue have. Or if they are not able to post their info soon, give us a call and see what it's supposed to be and compare to what you received.
If yours is the same as theirs, then we should be able to supply you with a longer one to avoid the problem ahead of time, rather than finding out during installation.
Regarding the filler extension's diminutive size, it's that way by necessity. This is a side-effect of having to push the tank up and down pretty much perfectly vertically, as opposed to being able to tilt it to clear the longer filler tubes. The adjustable mounting system pretty much negates getting much tilt action.
But other than it looking funny, here again I don't know anyone that has had any problems clamping the hose around it. Nor of any leaking from this area after the fact.
