Kentrol internet rumors?
swyman
Blissfield
I guess the best thing for me to do is call them but someone on earlybroncodriver's FB said that Kentrol is going to discontinue building the EB tubs this fall. I hope this is BS as I have not seen it on this site. Anyone hear anything?
lowbush
Summerland Key, FL
I cant see them doing a lot of tub sales with Bronco Design in the picture now. I don't know about the rumors but it's a small market for even one vendor. I wish someone would put out an aluminum tub but it's the same problem, the alternative material Bronco tub market is pretty small.
SteveL
Huge chevy guy
Hawthorne ca
A few years back someone was checking for interest in aluminum tubs on here but the numbers weren't there to justify doing it.
rastiss
Wichita falls, Texas
Aluminum tub sounds great in theory, however, how many folks would be able to repair them? For instance, the 2015 f150 is all aluminum. It's costing the average body shops 30-75 thousand to set up to work on them. Dedicated aluminum only hand tools, aluminum only repair areas separate from steel areas. I can't justify spending the $ for my shop for the return on investment.
badmuttstang
redneck grease monkey
Aluminum body work can be a little tricky but its not hard once you learn the tricks as for tools there's really not a huge amount of different tools if your already set up to do major body work at least from my experience. Sorry I did aluminum body work for 13 years when I was a painter so I'm just talking from my experience. I could see how it could coast some shops a lot up front to train someone if they have never tig welded or done work with aluminum but most competent body men should be able to pick it up quickly if they don't already know how. Once again my experience and my two cents.
hyghlndr
Hockessin, Delaware
Forget aluminum, I want STAINLESS.
Back to the original topic, I heard the same rumors. Unless they are much cheaper and primarily used for trail rig builders, I can't see a reason to not go with Broncodesigns as long as the prices are kept reasonable.
badmuttstang
What kind of rivet extractors are you running?
Sorry I guess I was just to old school we just used a good old fashion drill instead of self piercing rivets and a pneumatic rivet gun or bucked them in. We also used structural adhesive like ford wants welding should not be an issue where need if you have a competent weld and a tig welder a mig will work but you can control the heat so much better with a tig. This was all in a big rig body shop so I know what the "real world is" sorry. And in case your thinking we used small little rivets that everyone uses for standard work your wrong they were heavy duty ones just like ford would require.
swyman
swyman
Blissfield
No prob with topic. I worked for Ford at Maumee stamping and Woodhaven stamping and I can say with experience that aluminum is a bitch to stamp. LS fenders at Maumee and Mustang hood at Woodhaven. Hated those lines, although technology is improving but still tough stuff to work. I am going to call Kentrol and see for myself.
welndmn
I hate to drive this topic further off topic, but as someone that has an Aqualu aluminum body on a jeep, they are actually stronger than the stock jeep bodies, it's proven by being harder to dent in our comp rig.
I do wish they would try an EB body, but it's so complex I'm guessing it's not worth it.
swyman
swyman
Blissfield
Called this morning and they no longer manufacture fiberglass bronco tubs. I really missed the boat because they said they don't have anymore in stock either. Just bummed because they were $1000 cheaper than anyone else's I've seen and the people that had them liked them. Maybe the motivation I needed to just make it a race bronc and hang panels. What to do?
clarrance
You would have spent over a $1000 just trying to get the tub to fit, unlike the Terra Comp and Bronco Design. Kentol quality is no where near what the others (2) fiberglass companies tubs are.
Broncitis
MEB Founder
1. An aluminum body is very unlikely. The tooling required to do a Bronco is much more complex than the alumimum Jeep tubs I have seen done. High upfront tooling costs will be a huge barrier to anyone seriously thinking of executing this idea, and the price to pay off all that tooling will result in an unpleasant price to most who would be interested in buying one.
2. Kentrol tubs are no bargin at $1K less than a BroncoDesign tub. I got to see 4 more BroncoDesign tubs this past weekend that were delivered to customers at the Carlisle All-Truck Nationals and the new owners are making these look every bit as good and maybe even better than Mike did!
They had one there which the customer requested that the door inserts, fenders and grille be bonded on and seams smoothed for a true one piece look. It all lined up flawlessly with the hood. All their tubs come with firewall cut out locations marked. I bet the install on this tub will be 1/10 the time of a Kentrol or Terra Comp!
I have also heard that Terra Comp is for sale, so it looks like BroncoDesign is kicking ass and slowly picking off the competition.
swyman
swyman
Blissfield
Dammit! I didn't even know about Terra Comp till this thread and seen they had a shell only tub which is kind of what I've been looking for. Just sent them a email. I really wanted to do a full race cage and hang panels but I can't figure out how to get a cowl located so everything would fit right. If Terra Comp's shell is what I think it should be then it would have the firewall, cowl, and body sides all in one piece with the floor cut out of it so I could just lower over the cage and everything is in place. Just add fenders, hood, and grill... wala! On the other hand maybe bronco design could make me whatever I need from the sound of it?
swyman
swyman
Blissfield
Just tooled through BD's website for the first time and I'm impressed. Really like the trail tub with the built in inserts and pricing is good, plus they are within driving distance! Anyone know how much longer the "stretch" tub is? Bet they could do a stretched trail! I could lengthen that wheelbase and keep everything looking right. Thank you for posts!
Broncitis
MEB Founder
Drew, before cheerleading too hard for the BD product, may wish to reserve coment for folks with recent, first hand experience. There are some serious pitfalls. As time allows, I'd be pleased to share information by PM.
Rather than making a mysterious negative reference publicly that can not be addressed, share it here if you have personal insight on these.
I've seen these up close many times and have know several who have installed and finished them with no notable issues or problems.
