kick down rod connection at carberator
boss
Pittsburgh
I recently purchased a 1975 the PO changed the transmission from manual to C4 automatic. I noticed that the kick down rod is missing and if I purchase one I don't know how it connects to the motorcraft carb. Any help or photos we be great.
vintage bronco
if it was an orig std trans and now auto trans and carb is orig you will have to locate the correct carb for the auto trans it will have the provision for the auto trans kick down lever where manual trans carb did not have the provision.
B
boss
Pittsburgh
The PO had the carb rebuilt after the transmission was changed. I don't know for sure if it is for an automatic. How can you tell?
pcf_mark
On the driver's side there is a linkage behind (same shaft but closer to the carb body) the throttle rod. this is for the kick down but if you have M/T carb you are out of luck. Time to go to the yard..
jckkys
You don't need a new or different 2100-2150. You just need an automatic throttle shaft. The 2150 carb is calibrated to your engine. Finding an automatic 2150 that has the same calibration will be difficult. I'm sure I have the throttle shaft you need, that I can send for just shipping charge.
treihesse
Drill a hole in the bottom of the throttle linkage add a ball and hook it up. I had to do it to my howell TBI setup
bronconut73
I really like my Lokar kickdown cable.
Easy install and very adjustable.
I think JBG had the best price but any hot rod shop will have one for a C-4. They are not eb specific.
B
boss
Pittsburgh
Can you just use the Lokar for the kick down and stay with the existing rod from the accelerator?
bronconut73
Good question. I did the throttle cable first. But I do not see why not. It is independent of the accelerator linkage so it should be fine.
BTW. Our eb brother mentions above that WH has a cheaper one.
treihesse
Yes all the kick down does is tell the c4 to down shift during wot. It will work fine. Make sure you cut the cable incrementaly until it engages the kick on the c4
B
boss
Pittsburgh
Jckkys
I for got to give you my mailing address if you can still send throttle shaft.
Bob Kremer
532 McElheny Rd.
Glenshaw, PA. 15116
Thanks. Let me know what I will owe you
mafconc
kickdown at carb.
Pics of 73 if it helps.
