rjrobin2002
- Oct 13, 2007
- 2,706
New Efi swap that was running good on a engine i just removed it from and running bad once installed on mine. 91 Mustang mass air set up. Got standard emission codes in KOEO, have good 40psi fuel pressure that holds 40 even after turning pump off, timing is 10 degrees and advancing when rpm increases, and TPS checked out good.
What's KOER 94, 44, and 33 signal?
