Krawlers Edge cage
NYC Bronco
I'm installing mine tomorrow and I realize ti comes with no instructions, which isn't a big deal for the cage but I could use some guidance for all the assembly pieces for the seat belts. Any one have a PDF or other format copy? They provided a QR code to download instructions but the link is broken so no luck there.
N
NYC Bronco
So far it came out great.
now I have to install the seat belts
ngsd
I have one I put in one of mine too. They are pretty nice and fit well. Nice Bronco you have there.
SC74
This is the same cage I plan on getting. Your Bronco and cage look very nice!
72_EB
66to77
Looking good! I did one a couple years ago, but I don't remember that seat belt gap. I think bigmuddy is on the right track with some washers or spacers from the hardware store to take up the slack.
N
NYC Bronco
I sent a video to Kincer and in turn they forwarded it to Resto Belts are both say the install looks good and a little play is designed in and you can correct to your taste. I bought some clear at Home Depot, cut 1/4 rings and slipped them into place to reduce is not eliminate the flapping. I also feel like the belts themselves flap a bit so I velcro'd them to the rear cage posts to hold them in place. We will see how that goes.
ngsd
I would think the play is needed but something like a felt washer similar to the one on the clutch bell crank assembly would do the trick. Very nice.
N
NYC Bronco
I left the play on the drivers and passenger, they don't flap as much at speed.
Scott B
Has anybody removed the half cab and left the bulkhead in place and instale a
The Krawlers Edge Family Sport Cage ?​
