Last HydroBoost question...
904Bronco
San Martin, CA
Everything is hooked up and working with the 95 Astro van Hydroboost conversion using the 76-77 angle mounting bracket.
(77 angle bracket, EBay hydroboost bell crank retrofit, 79 Camero master, 77 Lincon 460 dual return sag pump, and local made hydraulic lines)
And WOW... night and day with the braking with 35" tires!
So I kept the factory proportioning valve/H-block mounted on the frame. Too much brake bias is going to the rears (lock up) and the dash brake light is on. I was hoping on keeping the factory set up and some have done that in the "Threads" I have read. Was there some specal trick that I may have missed?
Just hoping to be done and not have to bend up more lines with an aftermarket manual proportioning valve. (I already have the Summit valve part #)
Doug
Rustytruck
Did you lock out the H-block when you bled the brakes? You have to have a special tool to do this. You can get by by removing the light connector and putting a small screw on the plunger hole that is slightly too long and then lightly screw a 3/8-24 bolt in to lock the small screw. But now your H-block is off center so you cant do that. Have you pushed hard on your brakes and held it for a few minutes to recenter the h-block? You may have to hold the brakes hard and open a brake line to force a stuck plunger in the H-block so you can recenter it. I had a stuck H-block once and it was expencive to replace and then I found withthe right application of hydraulic pressure you could force it back over.
904Bronco
904Bronco
San Martin, CA
maybe you should call bc and ask about this LBS thing, it's about 2/3 down the page. I inquired about it, it seems cool, but i never tried one.
http://www.bcbroncos.com/rearbrakes08.html
good luck
Thanks. Never heard of this (LBS) before...
I was able to get a manual proportioning valve to work on my 4 wheel disc V8 EFI Landcruiser and my 88 Mustang track car, so I feel pretty confident that it will work here. Just ready to drive the rig after having it down for the a month + and not wanting to do more work with little free time.
904Bronco
904Bronco
San Martin, CA
No I did not... Did not know that there was a procedure... Hmmm
I will give this try this week, I noticed tonight when I started it up the light was off, but it came on later.
