FASTERDAMITT
Hey guys, I had my AOD rebuilt because of two things, the front pump was bad, and when cold it was hung in second gear not downshifting to first. Well it took two attemps for the shop to get it to stop hanging up in second when cold. Now that works ok but when I get on it, it wont shift into second until the valves float and I back off a little on the throttle (over 6k). Second to third is fine. When cruising it shifts late in first and way to hard for daily driving. I know they played with springs on the governor. I don't think they touched the Lentech valve body. I did check line pressure myself and it's right on the money. What should I look for?
