Latest Brutis Update!
Yellow75
Sioux Falls, SD
I rebuilt my tcase in an afternoon mnky.. Super easy to do. I was puking c4 fluid out the T-case output.
By far the hardest part of the whole thing is getting the damn thing back in!! It's damn heavy and shaped oddly enough that it doesn't want to sit on a jack nicely. It fell off the jack on me while trying to get the bolts lined up and my wife was running the Jack. I kind of freaked out, had her pull the jack out of the way and pushed it back up there somehow, then got a bolt in to hold it. Fighting around the crossmember is fun too!
trailpsycho
Yes, please tell us more about the paints/coatings you are using and your methods of application. Everything looks really, really clean. Keep up the great work!
brutis72eb
brutis72eb
South Carolina
Thanks Guys! I have been slaving over this engine for 1 week straight! I am exhausted and I am finished (except the exhaust but that will come later)!;D I put the adaptor on the tcase and cleaned and painted the carb and installed it. Put on all new spark plugs and connected all that up and finalized my odd power steering bracket (finally!%)) and put that on. I am having the C4 totally rebuilt for about $100 bucks cause Im friends with this guy and he builds these for a living. He said that will be ready by the end of the week so hopefully I can tow the chassis over to work so I can put the whole drivetrain on the chassis. I am driving up to Dennis Carpenter's in NC to pick up some floor pans and rocker panels on Saturday so I can start on the body work!
As far as the paint that I have been using.....I went to NAPA and picked up some Dupli-Color Hi-Temp Spray Paint in the Ford Blue and the Aluminum color. The black spray paint was Rustoleum on the engine. For the Dana 20, I pressure washed it and cleaned it with a wire brush. Then I sprayed a Rustoleum primer on it then used this satin black spray paint that we use at work to spray trannys with from a company called Spruce. The silver on the tcase was the aluminum Dupli-Color and for kicks I spray painted all the bolts black for some color contrast. Hopes this helps, I did not use any clear coat on ANYTHING I have put on Brutis. If it has that gloss look to it then thats how it was made by the paint manufacturing. Thanks guys and here is some pics of the engine just about finalized and the t case with the adaptor;) Ill keep yall updated
brutis72eb
brutis72eb
South Carolina
Oh yeah, sorry, the Dana 20 was not too difficult. Its not the easiest transfer case I have ever built but it definantly wasnt the hardest either. But then again I do this everyday for a living%). I would say it is definantly doable for someone that is somewhat mechanically inclined. It took me about 4 hours to do it all and that was teardown, cleaning, painting and the rebuild. My advice is go for it. You never learn until youve tryed. Its a fun little build and its even more fun when your building it for your own rig cause you get to build it how you want it and make it look how you want it. Good Luck;D
2badrotties
Just a Bronco guy !
Niskayuna N.Y.
If you spend as much time and get that picky when you do the body work, that should be a very nice bronco when done. The frame looks great silver and once you get that engine and stuff all bolted back together it should be like new again. Nice job ! :)
brutis72eb
brutis72eb
South Carolina
Thanks 2Bad, that is a great compliment coming from you a bronco god (*bowing*);D I sure hope the body comes out as nice as I want it too. I have a friend who just got done restoring an SS Camaro and he went bolistic! He went out and bought every single bolt on the Camaro brand new in Stainless Steel and ground off every single head of every bolt and polished each one before it went on the car. That is thousands of dollars just in bolts. But this guy is coming over and helping me with the body work and blocking out the body so hopefully it will be straight as an arrow once shes done;) Thanks again for the compliment;D
2badrotties
Just a Bronco guy !
Niskayuna N.Y.
I always try to give credit where credit is due. You are doing a great job, just keep it up. It is pretty amazing how much time you can spend sanding and sandblasting and painting all those little parts. That alone is worth a compliment because you have not quit. :)
Bronco Ben
Jckofalltrdes master/none
Coffeeville, Alabama
I Totally agree with 2bad!............ hopefully I will have a few bucks within the next two weeks to get my project started (Like it should have been long before now). Glad to see a really clean and painted trans case, and auto adapter. Pics are great motivation!....keep em coming! and Great work!
Ben ;)
