leaf and coil spring combo w/out top
jcb9089
Looking to add a 2.5" lift but will not be running a top, stock bumpers, 302 engine.
Will running WH 11 pack springs and coils for 2.5" have noticeable difference? Thanks
broncnaz
Not really sure what your asking here. 2.5 in is noticeable maybe not extremely obvious unless your parked next to a stock bronco. But it is noticeable none the less.
If you mean will there be a difference between the front and rear, I'd have to say yes. There are variables of course, but from your description it's likely to sit high in the rear for a long time.
The usual solution is to remove the 3rd leaf from the top, and even fine-tune it a little by removing the bottom leaf or two (the shortest ones) if the other one wasn't quite enough.
The little extra hassle up front nets another benefit though, and that's an even smoother street ride. Yes, you lose some carrying capacity, but it doesn't sound like that would be much of an issue for your situation.
That what you were asking?
jcb9089
jcb9089
Yes, that's it, sorry didn't clarify better. Was wondering how much of a difference it would be in the level between front and back.
Would 3.5 coils/2.5 leafs look better without modification of the leaf pack?
I would say yes. With your lighter-load situation, it should sit just about right pretty quickly. Maybe just a tiny bit of a rake with it high in the rear at first, but mostly level after awhile.
The only downside I see would be if you're carrying friends in the back a lot, it might squat a bit when loaded. But pop back up when unloaded. The springs do move when a load is placed on them. That's just the nature of the beast. Even the stock ones did that with the standard GVWR springs. The heavy-duty factory springs didn't squat much, until you loaded it up pretty good. But they didn't ride very well either!
bronconut73
I am running the WH 2.5" leaf packs.
Just got them. The ride is fantastic.
I was prepared for it to sit a little high at first. And it did. But it has only been about two weeks and only 3 rides and it has already settled about a 1/2" or so.
Really happy with this purchase. I put this off too long. I had Duff 3.5" 5 leaf packs for about 25 years. The difference is difficult to fully explain. But travel "quality" comes to mind....not just better riding. Articulation exceeds my shocks length, axle wrap is reduced, and even washboard is remarkably better. They seem to be a good match to my RS 9000's.
I asked about them here and Jim Creel pm'd me explaining why his cost a little more then threw me a discount that made the price difference nil. That did it for me. Paul and Jim are just awesome.
I am rarely this pleased with dropping $500 buck (with shipping) on something that I don't technically "need".
broncnaz
While I dont run WH springs I do run a 2.5in lift and with a hard top the rear sits lower than the front by about 1in. So without a hard top you should be close to level. I know WH usually recommends to run 1in taller rear springs when running a hard top so I would think that using the same height springs front and rear would get you where you want to be with no hard top
