T-7ToNewOldB
- Dec 7, 2018
- 315
Purchased the ford 9” rear housing from Wild Horses.
https://www.wildhorses4x4.com/produ...-Large-Bearing-Large-Bolt/Bronco_Rear_Housing
Along with their leaf spring and heavy duty axle bolt kit.
The pin on the leaf springs is larger diameter than the hole in leaf spring support welded to the axle. I assume I should just drill out the hole to the right size?
A little annoying as they sold me both parts and I incorrectly assumed they would fit together. . .
ID Spring Support 0.5115
OD Pin 0.6320
Thanks. Don’t want to drill if I should do something else.
OD Pin 0.6320
