No one in town as either the bearing or the seal......
Tim
Tim
That's my plan as of now.put some locktite on that and put it back in. Green is the correct formulation but red seems to work just as well.
I had wondered about it being a double lip seal. The stock 20 uses a double lip seal but from what I can tell the AA adapter uses the single lip? I think because the trans has a seal in it as wellGot the seal I ordered from WH as a back up. UGH....its not the same one that came in the dana 20 rebuild kit. It's a Timken. It is a double lip but NOT a double lip double spring. I need to call them on Monday. The one in the kit is much better.
Tim
I'm following what Tom's has in the adapter video. They used the D20 seal that's in the rebuild kit. Double lip double spring.I had wondered about it being a double lip seal. The stock 20 uses a double lip seal but from what I can tell the AA adapter uses the single lip? I think because the trans has a seal in it as well
I goofed. Fat handsJust ordered 2 from WH, got them and checked them both were double lips single spring, sending back. #18767 is the right one, no luck here in utah. 18676 is correct#
