GSP9
Transfer Case has leaked since the day I bought it. Initially, it was leaking from the fill plug and two of the lower bolts that hold the lower cover plate on. Took the fill plug out along with all the cover plate bolts, sealed the threads, put a new gasket on and they're not leaking anymore. Problem is, I have a new leak. It's small but leaks none the less. I don't think it was leaking from there before. Kind of thinking since the other leaks are now fixed, it's pushing fluid out of this spot. I circled in red where it is leaking from now. Does the bolt above the red circle go into the transfer case? When I had the bottom cover off I don't recall that it did but can't remember. What else is up there that it could be? Thanks.
