LED dome light **Update**
fallingdown
Do any of the vendors make a LED dome light replacement for the stock incandescent bulb? I want something much brighter than what I have now.
getfuzzy
check with BCB Chuck was into the LEDs. If not check superbrite LEDs on line.
73stallion
Eugene, OR
not to get off subject, but does anybody know where to get the dual adjustable lights like they used in custom vans and such? sorry to hijack.
fallingdown
fallingdown
I just ordered a "Vision X HIL-D6W Large White LED Replacement Dome Light" from Amazon. I will let you all know if it fits a stock Bronco dome light.
Stroppe-Envy-77
The p.o. of my Bronco did an upgrade, but with an additional light.
If you think about it, the problem with the stock dome light is where it's located, way up on the bottom of the wiper motor housing. Having it brighter will only help so much at getting light into the interior.
So, the dyed-in-the-wool Bronco tinkerer/restorer made a simple L-shaped bracket for the rear of the ceiling right above the liftgate. He then installed an inexpensive rectangular fog/auxiliary light (like you'd put on your front bumper) which points straight down at the cargo area behind the seat. It's wired to the same circuit as the stock dome light and they work in tandem.
It really does a great job at lighting up the whole interior, and even works when loading stuff into the back (p.o. used the Bronco for hunting and fishing trips). I can't imagine the whole set-up cost more than $20.
fallingdown
fallingdown
**Update**
I just want to update you all on my progress in locating a LED replacement bulb for my stock wiper motor cover. I ordered an "Vision X HIL-D6W Large White LED Replacement Dome Light" from Amazon. About a week later I received a package from "G International Group" the packing list says that they sent me Item No. 6411WH "Eurolite" (6411 LED Mini Bulb White). The bulb is exactly what I wanted, it fits perfectly into the wiper motor cover with no modification. The light is at least twice as bright as the stock bulb and bright white in color. I spent $18 including shipping for this bulb. I would highly recommend this bulb.
(954)972-1920
www.ginternationalgroup.com
