Lee Power Steering kit for Explorer 5.0 to EB
ba123
CA
I got the reservoir and like it and if I ever need a stronger pump, I’d go that route since I want to keep the explorer setup for how I have things.
toddz69
I got just the pump recently to try but haven't installed it yet.
Todd Z.
ba123
CA
Todd Z.
What did just the pump cost? Would be good to know if I’m not happy with the stock pump. I just bought a new one but they are cheap.
toddz69
It wasn’t cheap either. About $475-495 plus the pulley and adapter bracket. Been doing a lot of research on the Saginaw CB pumps. Apparently they’re a good thing.
Todd Z.
ba123
CA
Yeah, not surprised on the price. I thought about going Saginaw but the stock explorer bracket seemed like it would work better for me. Will see how my steering g is and then if unhappy, I’ll go that route.
ksagis
Aspiring Bronco Guru
Austin
Todd Z.
Todd, any reason you didn't do the @lars Super Duty pump guts swap into Explorer pump before going this route? From my read of his post, it seemed like a valid upgrade that is effectively bolt-in since same form factor.
@lars, any update from you on that mod?
toddz69
Lars and I have discussed it many times and I decided it probably wasn't worth it. I must have a p/s pump fetish or something :). I have several different configurations sitting around here in my collection.
Todd Z.
ksagis
Austin
Todd Z.
:) p/s pump fetish, brake MC fetish, visor fetish, windshield wiper fetish, etc. It's rather long list of Bronco fetishes (that I'd be proud to have!)
lars
Been here awhile
NorCal flatlands
I've run my modded pump twice. First, right after I did the mod. At the time I still had an OEM 77 power steering box and I was afraid that the extra pressure could damage it. Subsequently removed that steering box and sold it for an immense profit. Now 4x4x2 and not concerned. I installed the modded pump again when I did the 408 swap a couple of years ago. It worked fine until the seal blew about 6 months later. I reinstalled the junkyard pump that I've been running since 2005 or so and will not die. In fact it works fine, and honestly I couldn't tell the difference performance-wise between ancient junkyard and basically brand new Super Duty. I've read the stories of others with Explorer power steering pump issues but I've never had any, at all. I don't do extreme crawling, my tires are 35" and I don't have a ram, so that's likely part of it. Someday I'll probably replace the seal, most likely if ole' reliable finally gives up.
lars
Been here awhile
NorCal flatlands
Anyone listening to the (very) long conversations that Todd and I have, obsessing about obscure and not-so-obscure Bronco details would probably collapse onto the floor. Or leave the room. In fact I can say with confidence that the latter has happened, fairly regularly.
ksagis
Austin
Appreciate the followup. I had assumed the Super Duty mod increased flow, and *maybe* increased pressure. I need to go back and read your article again.
lars
Been here awhile
NorCal flatlands
It definitely increased pressure, substantially. I was able to measure that. I did not have a way to measure flow- maybe I just wasn't clever enough- so I don't know about that.
1sicbronconut
I've enjoyed those conversations over some good Gin :)
See Lars? Maybe it wasn’t the conversation that put others on the floor after all.
It was the associated drinkin’ that did it!
  • Like
Reactions: POG
ksagis
Austin
I was just typing “if it increased pressure, then it also increased flow” but then I seemed to recall on Explorer style of pump hydraulic flow, thats not the case.
Hmmmmm. Currently reaching for a refill of my favorite refreshment for deeper reflection.
