Let's play Guess...That... Noise!
Amitchla
Hi guys,
So, I've been chasing a gremlin in my drivetrain for sometime now. Quick sum-up:
1A. The truck developed a roar/vibration on the highway. I had been driving at around 70mph for 50 miles, and began to smell gear oil. I hopped out, but didn't see a leak. Within another 20 miles I had a very bad roar/vibration that started around 35mph and got much worse from there.
1B. The noise occurs in RWD, not FWD. It occurs under load/acceleration only (not during deceleration in gear, not with the clutch in while in gear, not in neutral).
2. Bronco-specific mechanic in Venice said it was my transmission (which didn't make sense to me). To note - he installed a new Truetrac within 200 miles of the problem beginning, but insisted the noise was not coming from the rear end.
3. I then had the driveshaft rebuilt, and the heavy duty Output Shaft components from WH/Advance Adapters rebuilt by AA. No change.
4. I wanted to swap in a 5spd anyway, and thanks to Covid, suddenly had the time to do it myself, so I completed the NV4500 swap. This included redoing both driveshafts... again. Noise is STILL THERE.
5. I took the truck to a rear end specialist. He said the driveshaft angle was too steep, and that if I corrected that, it would solve the problem. This also didn't jive with the way the problem developed in my mind, since the noise appeared after a period of driving. I could see it being the driveline angle AND a worn out <insert worn out part>.
6. I (temporarily) lowered the transmission cross member one bolt hole, which equaled around 1-1.5". This took the driveshaft angle from 20deg to 16deg. No effect.
7. I called my driveshaft shop to see what they thought about the angles. They mentioned either 20deg or 16deg would be "fine, but 16deg is better, of course." He mentioned that, perhaps, the pinion yoke had been warped as a result of a stripped u-bolt on the driveshaft, which I had initially when I went to take off the driveshaft the first time.
8. Today, I changed the pinion yoke. No effect.
Below are links to two videos. I uploaded them to YouTube because I can't get them to upload on the forum directly... either too big or the wrong format, or both.
The first (floor installed) is driving from start through about 40mph with the ol NP435 installed. I start the truck in second, and you can hear the noise begin at the end of third, and heavily in 4th.
https://youtu.be/TaxLhLXbix0
The second (floor uninstalled) is driving at slow speed with the NV4500. There is a noise that you can hear distinctly around the 20sec mark.
https://youtu.be/FUU09u9jgyc
So - any ideas? I'm stumped.
73azbronco
I think your front driveshaft is turning so, unlock hubs, put d20 in N.
I would say solve the angle like the specialist says, if that ain't it you have an axle/yoke issue?
Yes I heard a different than expected noise but have to chuckle every time someone posts a noise, they all sound like a bronco to me:)
A
Amitchla
@73azbronco - yes, the front driveshaft is turning, but FWD was disengaged. I had just verified for myself, again, that the noise only happened in RWD and not FWD, I just hadn't unlocked the front hubs yet.
If it is still the driveshaft angle, why would it have started randomly after 50 - 70 miles of high speed driving? Meaning, if it took that long to develop, then something must have worn out gradually during that time, causing the noise to begin after driving for a while, rather than happening anytime the vehicle was driven.
I can't imagine it's an axle, as it only happens under acceleration. If it was an axle, it would ALWAYS happen, regardless of load, since the axle is always spinning when in motion... I think?
langester
MASTER OF MADNESS
Not sure if you tried this or not but worth a shot. I think I would put the Bronco on a lift or jack up the front and rear axles and put them on jack stands. Have someone get in and start it up and run it through the gears while you are outside the vehicle watching the drive train. Maybe you can pinpoint where the noise is coming from. Just a thought, good luck with it!
73azbronco
got a go pro or friend with one, try taking shot from front pinion then rear, see if sound is louder at one point.
EPB72
Pleasant Hill, CA
My thought as well.. and a mechanics stethoscope to help pinpoint.
how's about some pics of your rear driveshaft? Front, back and one shot of the entire thing end to end.
sprdv1
REBEL
Pics could definitely help too... welcome to the early bronco world haha
Seventee
In the sticks of MT
I think it's in the third member, especially since you just had work done on it.
You only had a TruTrac installed, no new gears correct? If so he blew the gear setup - with used gears he should have set the backlash the exact same as before it was taken apart. I bet he reset the backlash to spec and now the gears are toast.
SteveL
Huge chevy guy
Hawthorne ca
I'm also thing 3rd member. You didnt let 4wp install the true trak did you? The diff guy I use gets a good amount of his business fixing their screw ups.
A
Amitchla
Unfortunately with my shop set up (or lack thereof) and the extreme flex ability in the suspension, I don't really have the ability to get it off the ground far enough to drive it on jack stands.
I've attached photos of the driveshaft (full, front, and rear). I unfortunately didn't take any new pics of the former angle prior to dropping the transmission down 1" (lowering the crossmember down one bolt hole).
As mentioned, the current angle as measured on the driveshaft itself is 16 degrees, and it was 20 degrees prior to this jury-rigged transmission lowering.
@Seventee - this idea was mentioned to me from another Bronco owner as well.
@SteveL - I work with ASC Bronco in Venice, but he outsources the differential work to someone I'm unfamiliar with (which is hopefully NOT 4WP, lol).
put the Bronco in 4wd and lock the hubs. remove the rear driveshaft and then drive it with no load on the transfercase rear output and no load on the rear the drive shaft the noise should not be heard. also while driving as is put two fingers on the shifter shaft and then the transfer case shaft when the noise comes in and see if you feel the vibrations echoing up the shafts. That may help you find a path forward. when having the diff work done did anyone stop and look at the rear axle bearings while you were in there. when doing the diff work did they replace the pinion bearings and reset the pinion gear too?
SteveL
Huge chevy guy
Hawthorne ca
You're not that far from me. If you want it checked out call Frank at south bay 4x4. Hes one of the better guys for diffs and also does suspension work. I can add his number when I get home. I've also got a pretty good driveshaft guy over in gardena near the 110 & 91 interchange.
A
Amitchla
I just rooted around and found the receipt for the differential work. It looks like they charged me for the differential and a "rebuild kit." They definitely did not replace the Ring/Pinion, which could support the blown gear theory.
@SteveL - sure - send over the info. Always happy to receive new rec's on good mechanics!
sprdv1
REBEL
def go w/someone known by Steve...
