broncomitch
I'm running full hydro steering ,Chevy hydro boost, duel piston ford calipers up front and the normal Chevy disc brake conversion on the back with a CNC cutting brake for the rear only and I'm using the stock early bronco drum-drum proportioning valve.
My brakes have always sucked and the proportioning valve is the only part on the braking system I have never messed with and wondering if its cus of that.
I have not blead my brakes all the way cus i have not plumed in the cutting brake yet (waiting on shifters) and I can already tell that the hydroboost is a huge improvement but I'm Wondering if I should ditch the proportioning valve and plumb the lines together? Or Get a disc-disc proportioning valve.
I'm sick of having crappy brakes and want this thing to stop the best that it can so I'm Also thinking of getting drilled and/or slotted rotors and was wondering if anyone knows of a good and or cheap set, I found some on summit for the front that I think will work but nothing for the back.
Front is a 88 ford kingpin dana60 and the rear is '73-'87 3/4 ton, 4x4, Chevy front Calipers & Rotors
Both are 8 on 6.5 bolt pattern
Now, obviously this is not street legal any more and is a dedicated rock crawler and the most it will see is 50mph.
