- Aug 24, 2006
- 1,328
Hopefully these photos show it better. Cable brackets go straight back. Cable goes down through a hole in the floor of the console near the back, and through the floor of the Bronco. Then over the top left of the Atlas. The t-case is so big that there was no way to get a straight (horizontal) shot to the shifter arm on the side of the transmission, so I had to make a custom shift cable support bracket that bolts to the side of the 4R70W, and a custom shifter arm, so the cable could angle down and forward. It was a PITA to get right but it worked. My DD is a Toyota Tacoma pickup with the usual center console auto shifter. The location I wound up with for the Winters shifter puts it in just about the exact same place relative to my seating position, which turns out to be comfortable for me. YMMV.
The initial design for the extension was done in SolidWorks. SendCutSend made the pieces. Cupholders came from Summit.
View attachment 941786 View attachment 941787 View attachment 941788
That is the exact type of info I'm looking for.Oh yeah it could be that my Tuffy box is 9" wide- 8" was a guess. I'll measure today.
I have seen others clock the rail mechanism on the winters shifters, but I didn't see how it was actually done. The box you used I think is the same style I have already, so basically copying that design wouldn't really be too hard to follow. I've considered purchasing a sheet metal bender so I can then start compiling other tools that will eventually take over my entire garage space and empty my bank account...
You wouldn't still have the specs you sent to SendCutSend would you?
Another option I've considered it using 1" x 1" metal tubing to build the structure then sheet it with 18-16 gauge and utilize nutzerts to hold the covering down.
