AU Bronco
" I think i have decided to run wildhorses 5.5 leafs and their 5.5 rockcrawler coils. Any opinion on these? Im also getting a 7 deg bushing kit and some rubber deg bushings for rad arms. Is their a perfered bushing kit out there? "
With 5.5" lift and 7* bushings your font caster will be negative, it rtquire around 9-10*. For a while BC sold 10* bushing but it apears they are not available anymore, try calling them though. Typically with 5.5" lift you need to either drop your radius arm mounting brackets, use longer radius arms, or correct your caster by modifing the axle housing (most rotate there knuckles back.)
You could drive it w/ 7* bushings but the road manners would questionable, and there would be little to no return to center in the steering.
