Ok, this has probably been answered before, but I am looking for the distance between the rear axle spring mounts and a line drawn between the spring eyes on a stock bronco. I replaced my rear axle years ago and went with a heavier spring pack to eliminate axle rap. I solved that problem, but the rear sits higher than I'd like, so I need to determine what size lift to buy to replace it. My current dimension is about 6" and the springs have 6 leaves. I am running F150 front coils and some body lift-1/2" in the back and close to 2" in the front. The truck currently has about a 6" rake. I would like to see that about 3". I have a '77 with a '74 rear axle, and I usually run it topless. If I cover it, I use a half cab. Right now the body is all steel, but will probably go glass someday. I think that is all the important points. I would welcome input.
