Liftgate bolt latch assembly
BoulderBronco22
So the previous owner had put cotter pins into the liftgate latch assemblies and so it was preventing it from going that additional 90 degrees necessary to seat the bolts all the way into the striker plates. I have some roll pins but I am wondering how the entire mechanism fits back together since I haven't seen a properly assembled one.
Anybody got pics of theres or can explain how everything fits together?
Thanks-
Mike
plumbdoctor
Golden
Mike, take the cover plates off, unscrew (bolt ) all your pieces. Remove cotter pin from center tumbler, slide pieces out. Remove pins and replace with the roll pins. Re assemble.
Should have done that here, but would have been a noisy ride home
BoulderBronco22
BoulderBronco22
Thanks Keith-- I got it. I did not know how the rod mated up with the bolt and how the roll pins went in but figured out that it sandwiched in between the end of the bolt. It is in and MUCH MUCH tighter-- hoping that takes care of the rattling.
