- Oct 8, 2019
- 587
I tried to install the liftgate latch a couple weeks ago and had a few issues:
When tightened down the latch bound up in the cut out on the lift gate. I filed that down and got it moving freely
Second problem was the flat ends of the rods wouldn’t fit in the slots on the latches. Again, filed them down and got them moving freely.
The last problem I have not resolved and could use some advice. The 1/8 pins don’t fit tight in the rods. When opening the hatch spring pressure is released from the pins and the move and eventually fall out. The pin under the spring I have to hammer in with a roll pin punch, the ones in the rod I can push in with my finger.
Is there something I can put on them to hold them in place (loctite?). Or should I take it back apart and drill the holes to 5/32 and use larger pins?
