Lightforce lights
chuck
Ingram, Texas
As you ask so nicely I can. I did not check the price on the harness but will tomorrow. No one has ask before.
chuck
Ingram, Texas
That video is pretty amazing! Bullet proof lenses!:eek: I am interested in a mass buy if I can come up with the funds.
When I rolled the racer in Baja a few years ago we had 4 Lite force lights on top. During the 3 rolls 3 of the 4 lites were damaged. 1 showed no damage, 2 had broken mounts and the 4th was behond repair. I run 6 on the racer now, 4 on top and 2 where the stock head lights were. I am still running the first 3. Because they are adjustable I run the lower 2 as flood lights and the 4 on top as pencil beams 2 mid range and 2 long range. We have to turn the top lights off as we get close to the pits.
rob wilson
Flagstaff, AZ
Count me in for a Enforcer kit. These things are incredibly bright and the cool thing about the enforcer is it also has three LED's that can be used instead of the primary bulb for low intensity lighting needs (reading the map). It'll be great for night Search and Rescue work I do as a volunteer.
TJK74
Newark CA
Man I'm liking those 240's but fitting them on the bumper with a winch might be a bit tight. Might have to settle for the 170's
sstlaure
Bronco Slacker
All right.....who's in? I assume we have to hit the 15 mark to get the deal. I've already got mine on order. Are we going to hit the (15)?
sstlaure
Bronco Slacker
Come on people....you know you want these on your truck to replace those puny little KC daylighters. :p
Who doesn't need 1.4 Million candlepower of light. (or 2.8M in the case of what I'll be running.) :cool:
Coachbarnes/Chuck,
Are you running dual batteries and high output alternators on your trucks? I assume you need significant voltage to drive these suckers.
coachbarnes
Franktown/Breck, CO
Coachbarnes/Chuck,
On the racer, yes -- but that's really more of a redundancy issue. I run 3x170's on my tow rig (F-350) with stock electrical/battery, and use the built in switch that Ford provides, so no additional relay required. These lights ROCK. I wrecked my 350 - Ran off the road last year, right through a tree and a hundred feet of fencing. About 10K damage to the truck. All three lights survived, with the exception of 1 bulb needing to be replaced. The housings still look brand new.
Here's a pic of the truck with the 170's in front.
sstlaure
Bronco Slacker
I'm going with (4) 240's across the windshield, 2 spot, 2 flood....should light up the night nicely. I'm only getting (2) lights right now so I can get the rack all fabbed up.
Thanks for the info...I'd be willing to bet your F350 comes with a fairly high output alternator stock.
chuck
Ingram, Texas
Just talked to the light force rep. and got a little better deal on the lights so I am passing it along. I corrected post 38 again.
