"Lil Rusty" My second Bronco
tasker
all knowing of nothing
NH
GREAT WORK!! let us see how this turns out! going to able to use that cowl piece?
.94 OR
Willamette Valley, OR
Are you using a burn through primer on the seams?
Going to be helping my neighbor put some floor board patches in a Triumph TR3 and I'm busy taking notes.
migs
Sweet! Looks like maybe you are going to get into the restoration business...
Wait... are you telling me I could get paid to work on Broncos??!!:p;D
We'll see, but could be a while... Hmm, i'm going on five years with mine, and it wasn't even rusty! Shhh... don't tell Brian that!:-X
WOW!!! Nice work Brian, there's an led light at the end of the tunnel lol
there seems to be a lot of light shining through the sheet metal.:cool:;D;D
No, just welding good clean metal to good clean metal. then I focus on sealing it all up with a good seam sealer. I used a two part SEM product on this.
fatboy
Glad to be here.
New Hampshire
Well you might have to find a different group of friends first since we are all "frugal" New Englanders! (That should be read as cheap @$$ bastids! ;D)
tasker
NH
honest, not too pretty but honest! :-*
Slednut10
Guru? That's funny!
Hey, hey, hey, I resemble that remark...........:p
Nice work as always, B!
migs
So you're saying there's some clean metal on lil' Rusty? Well, I'll be damned! :eek:
Well... there was, but I think I've about used it all up!;D;D
I started on the drivers side pan. didn't get as lucky with the welding of the big nut to the body mount bolt. bolt was rotted and snapped off. but... I was able to thread on and weld a nut to the bottom of the bolt sticking out underneath and back it out that way. so you are good to go with the old bushings!
migs
So here's the progress on the driver's side floor pan.
First, what I had to start with, and after removing the rotted metal. then fitting the new pan after trimming it down some along with the vertical piece I made for the front of the seat platform.
migs
...here it is welded in and then after grinding the welds down. Tomorrow I'll apply the seam sealer and prime it.
Just realized I forgot to show how I had to rebuild the little support ring around the body mount bolt hole inside the floor channel support rail on this side before I sealed it all up. oh well, it's in there though so the bolt won't suck the pan down to the bottom of the channel.
migs
And... floor pans are done.
now to just wait for the other rusty metal to fully disintegrate and fall off.;D%);D
migs
How about some teaser pics with the replacement lower rocker skins temporarily stuck in place... makes her look a lil better on the outside anyway.;D
