Locking hub question
redfishtony
Thomasville GA
Ok what’s the trick? Took the snap ring off and can’t get any further. Just don’t want to damage anything I can’t easily replace.
Both snap rings? There is the larger one in the outer groove of the hub itself, and a smaller one that I think I can still see clamped around the tip of the axle shaft in the center.
Bronco 4 life
Yakima
This guy needs to come off
redfishtony
redfishtony
Thomasville GA
I got it. I had the outer ring removed but I but to push the two tabs in and then the first big ring came out. I didnt have to remove the small center snap ring until I pulled the spindle off. I tell yall these are some beefy hubs. Nothing like the modern cast/lightweight hubs. Way better from what I can see. Thanks guys, TW
