airbur
Thought I'd post up some pics and info. I was hesitant about going with these as others said there were install issues. Only mod I had to make was the kick down connector on the C4 had to be bent out slightly. This was needed because I'm using a B&M shifter linkage.
The curve out of the firewall isn't that bad as it wraps around the rear of the intake. The length of both cables is fine and give you room to cut depending on your install.
I haven't tested them in use yet but will soon. The bracket uses the stock Mustang EGR delete spacer holes. You want to talk with Duff though and tell them what type of attachment your particular throttle body uses for the cable.
