Long Snout Harmonic Balancer
tk1218
Flower Mound
I have several 302s that have a longer snout harmonic balancer that makes the 2 grove pulleys I have not line up with the alt and power steering pump, the grove are too forward.
I have seen mention of this issue in my research but haven’t really seen a solution.
Does 1 of the vendors offer a 2 grove pulley for this type of balancer?
I see a March 1631 on summit that might work based on how it looks
Hard to say. Do you know what the balancer is from originally? Did it come on a swapped in engine?
Unfortunately Ford had a real passion for non-standard sizing on Windsor family components. Including harmonic dampers and pulleys.
At one time there were no less than 21 individual aluminum timing covers! I've got a box around here somewhere (and a Homer bucket too!) full of Ford pulleys that hardly match each other, much less any engine I ever tried them on.
Sorry I don't have any helpful hints yet tk. Maybe post up a pic of it so we can see. Maybe it's originally a serpentine damper? Not sure if that makes a difference, but it might.
jckkys
It's not OE on a '77. In '70 I believe Ford went to the long 4 bolt damper on everything other than EBs. You need an EB 3 bolt damper and matching pulley. Some had a lip on the pulley and some had a lip on the damper.
If this is the original engine and damper, what are the pulleys from that don't fit?
If it is in fact original, then any of the pulleys specifically for a Bronco should fit and line right up.
Does it have three, or four bolt holes for the pulleys?
And we definitely need pics. I thought I knew what you were referring to, and thought I'd seen those on later Broncos, but jckkys' knowledge about later, and specifically '77 EB's is pretty extensive.
Let us see a pic and see what there is to see.
If you can't put it in your Gallery you can e-mail it to paulb@wildhorses4x4.com and I can post it in the thread directly.
Might as well take a couple of the pulleys in question too.
rcmbronc
Tomah WI
March 1545 works for the longer pulley with 4 bolt balancer. The vendor ones are made for the shorter balancer. With my research there were two lengths of blanchers but there may be more.
jckkys
If you use an original EB replacement damper it WILL be a 3 bolt type. It will also have a 28oz. imbalance. These will work on any '66-'77 Bronco and most pre 1970 289-302s and all 351Ws. The 4 bolt dampers came in several configurations including both 28 and 50oz. imbalance. That's not a problem because none of the 4 bolts work with EB pulleys and brackets. The March pulley is not an EB compatible part. Here's the correct damper ;https://www.rockauto.com/en/moreinfo.php?pk=5431008&cc=1105355&jsn=743. Summit is a poor place to find replacement parts.
Here ya go:
Since this is an unknown engine from someone else's unfinished project, and since it sounds like no EB's ever had a 4-bolt pulley, then it's a good bet this is not an original EB engine.
Or if it is, other things have been changed on it.
By any chance, is there a dipstick in the front timing cover?
If so it's out of a passenger car or 2wd truck.
And while you have such good access to the alternator, might as well find out if it's wired properly.
Will you be running a Ford carburetor with an electric choke by the way?
vincevs
I have the same issue on my original motor '77 302... I replaced my entire rotating assembly with a balanced 331 from eagle and it came with the same balancer in your photo. Since it's already installed I would really like to find a shorter pulley that would work. Did you have any luck? Does anyone have a part number for a 4 bolt shorter double pulley?
rcmbronc
Tomah WI
vincevs
I saw you posted this earlier in the thread and it still has me confused as I need a shorter pulley.
Not trying to be difficult, just making sure before I drop the $100.
Do you mean this is a replacement shorter pulley that works with all the original accessory drive and setup when using the deeper/longer balancer that is shown in the above photos?
rcmbronc
Tomah WI
Correct. I use it with the longer balancer and all the stock accessory drives. It is a shorter pulley set up than factory or the ones the EB vendors sell.
