Long tube header install
duderhimer
Wichita
Have a silly question, I have a 1974 with a 302 I'm considering installing long tube headers, the question is has anyone attempted an install without pulling the motor. If the enigine has to come out I may wait until I freshen up the engine. Thanks
sykanr0ng
Some long tube headers wrap around the engine mount, two tubes in front and two behind.
I have seen on a Bronco where the flange was cut in two so that it could be spread enough to get it around the mount.
Can it be done?
Yes.
Is it the easiest way?
D
duderhimer
Wichita
To answer tmaddux911 question I've installed headers in several different models of cars and trucks except an early Bronco and all models are different, some go right in others you can get away with rocking the engine one way or the other to wiggle them in, some the motor has to come out.
Was hoping someone here had installed long tube headers without pulling the motor.
tmaddux911
I have long tube headers on mine and there is no issues what so ever. Thats why i was curious why you would think that the motor would come out.
RODRIG3911
Tucson
I also installed mine from the bottom up.... Had to take clutch/brake brackets off on the drivers side, but it wasn't too bad once I stopped trying to install them with that stuff on lol
nvrstuk
PNW
Go in from the bottom and if you have a two-part type that pulls apart and goes around either side of the starter sell them and get different ones!! Those are old-school and develop a lot of heat for your starter.
rwill
Two times. WH. headers both times, 2nd set where a pain,loosen motor mounts take trans linkge loose. 1st set fell right in they can be a pain is my point.
rwill
Well sorry 'bout that last one there rwill. They're "supposed" to go in without trouble. But well, you know how that goes sometimes with our Broncos.%)
Did a set on a '73 last year and went in from the top on one side, bottom on the other side.
This one was an automatic with power brakes, and that does certainly make working on things more intimate.
You already have a set duderhimer, or still thinking of buying? Some of the old-school manufacturers were known to have clearance and install issues on EB's, but I would think that a set from one of us Bronco vendors would work without too much drama.
Good luck.
blubuckaroo
Grease Monkey
Ridgefield WA
I`ve installed long tube headers in a couple of Broncos. Both with the motor in.
I have to say, I learned from the first.
One goes in from the bottom and one from the top. I can`tell remember which.
I found it necessary to jack the front of the car up very high to get a proper angle from the bottom. Be careful here! Use good safety stands.
If you`really in the market, the Hooker mid lengths are lot easier to install, and with better ground clearance too.
pcf_mark
I used Hedman and the passenger side comes in from the top and the driver side in from the bottom. Take off all the plug wires and remove all the plugs then it goes pretty quick assuming you can get the old manifolds off w/o any problems.
