Long Tube vs Shorty Headers
The Far Side
My PO had a set of long tube headers on the 351W that came with my Bronco. I plan to go back with a version of a 351W set up (rebuild current '69 motor or go crate stroker).
While removing the engine and components, the Long Tube Headers were a real pain to get in and out. I know there are more advantages to them from a performance standpoint but do they outweigh how tight the engine bay is? I would sacrifice a some horsepower/torque for easier access.
Am sure someone can give me the pros and cons.
Wayne
Digger556
For 90%-95% of applications, long tubes are over rated and often are too large. I switched from long tubes with big primarys to short tubes with smaller primaries and didnt notice any difference. Engine was a healthy 351W making 375-400HP at the time.
Here's a photo, not a big difference in length, but much much easier to route exhaust and get parts in/out.
chuck1022
I have watched 125,000 hours of youtube content on engines and headers.
LoneRanger
Gunshine State
I find it impossible to believe that short tube headers don't make more power than stock manifolds. We pulled a 96' roller motor from an explorer. The stock manifolds were atrocious! We are just doing a refresher with an rv cam and shorty's. Can't wait to see what its like!
L.R.
JohnJohn
Richmond
My Bronco is no race car so it may not matter but I prefer the additional HP long tubes provide. I just finished a custom 2 into 1 on my trail rig because no one makes a 2 into 1 for long tube headers.
Here is a good article comparing long vs short vs stock on a dyno from HotRod.com
Final results from the end of the article:
"After running the stock manifolds, it was time to install the shorty headers. We made quick work of that task and were somewhat surprised that the shorty headers offered no change in the power output over the stock manifolds. We have run many tests on shorty headers and have seen small gains, but on this mild 351W, the shorty headers produced not just identical peak numbers, but the entire curves were the same. This changed after installation of the long-tube headers, as the 1 -inch Hooker Super Comp headers (for a Fox chassis) improved power production through the entire rev range. The peaks jumped to 420 hp at 6,100 rpm and 429 lb-ft of torque at 4,300 rpm, but torque production improved by over 20 lb-ft below 4,000 rpm, proving once again that real headers are long and strong!"
SteveL
Huge chevy guy
Hawthorne ca
I remember somebody posted the actual numbers on this. Not sure if it was the same article but it had the same results. I've pulled my long tubes in and out a few times without much trouble. Mine are duffs.
LSUpete
I know that Chuck at BC Broncos did a ton of research and testing and he determined that, ON A CLASSIC BRONCO, the shorties with a 2-into-1 exhaust system yielded the best results.
vintage bronco
L.R.
LR you would be correct why would Ford spend money tooling up short tubes or 5.0 Mustang if they were same as manifold ???
chuck1022
I dont see the benefit for the way I drive.
The price for headers is not worth the marginal gains....especially at rpm's I dont visit.
If I had an FFR Cobra....4000-6000 rpm's is awesome.
I drive my bronco from idle to 3500
savage
Bronco Nut
Renton
I had long tube headers on my 74, they really heated up the passager floor board. So I changed to the shorties and really didn't feel any power difference.
bronkenn
Bronco Guy
Southeast Ohio
I also have Duff's long tube headers and they are easy to install/remove. The bolts in a few places were a little tricky to tighten but otherwise satisfied.
The Far Side
The Far Side
Thanks guys for all the input. Am going with my original thoughts and go back with the long tube headers. I like the performance boost and once they are on, I don’t plan to remove anytime soon.
Thanks again
