Longer Arms, or Link the front?
Bronco69Sport
Upper MI
I am in the process of narrowing down my suspension setup. I have heard that the longer arms will work as well as the link system, but without wearing out the pivot points nearly as quick. Is this true, or should I spend the extra coin, and get the link setup? Too many options. I need some guidance please!
Thanks.
Recko555
I am going to extend my radius arms on my dana 44. If I was going to link my front, I would do it to a dana 60.
1WILD69
south range
Mine is linked in the front with leafs in the rear. If I had it to do again, I'd link the rear and use the long arms in the front. The long arms are worth it from what I have seen. They flex well and are a lot lower maint. than my links.
sstlaure
Bronco Slacker
You're limited more by front driveshaft angle than you are the ability of the suspension design to travel.
With the links you can eliminate bump-steer and side to side movement of the axle assuming you go hydro steer, whereas with the trac-bar you will always have some amount of axle pull due to the side to side movement induced by the design.
My truck with the trac-bar is getting almost identical travel to my friend's with his 4-link.
TN1776
4-link design is a major factor in how well it'll work. Having spoken to several people who've linked front or rear, long arms are definitely a more "off the shelf" solution - links require much more knowledge of how suspension works and a lot more "brain work".
I chose a pair of Cage arms for my front end...
1sicbronconut
There's a thread on this right now in the tech section, I just posted some good links on the subject.
Bronco69Sport
Bronco69Sport
Upper MI
Thanks for all the info, and the tech section notice. I will take a look at that as well. I do not know suspensions, etc. that is why I am leaning towards long arms, and a better leaf pack for now, that way I can study the linking process over the next year. Thanks again
