73bronco
- May 10, 2007
- 936
Will an stock gt40 EFI lower intake manifold bolt up to just about any head? I was planning to just put the EFI on my stock '72 motor and run it but then I figured I may as well look into heads. I may have a line on some GT40 heads as well. Will GT40 heads bolt onto my old block? I am not looking for a lot of HP but I am looking for some nice torque. I am also looking into a cam change. I will change it to the H.O. firing order since it will be injected. I don't want to spend a lot here. Give me ideas for a head set and cam kit under $800 together!! This is a rock crawler that occasionally see the road and the stock engine is just too weak to push around 36's and 4.11's. The stock engine has been fully rebuilt recently so the bottom end is in good shape and would be worth working with.
