- Nov 3, 2003
- 49,351
...plz let me know if there are other angles or pix of parts I should upload in order to determine best course of action...thx!
Thanks for the pics. Definitely get some of the rear too, while you're in the mood.
And maybe one or two of the overall vehicle's stance while you're at it.
And speaking of the radius arms... I can't tell for sure, but are the "kinks" (the bends in the middle where the diamond reinforcing plates are welded) bent inward, or outward?
Your front pinion angle is not happy. It's not horrible, and doesn't look like it's totally whacked. But it's getting pretty steep. That's where the driveshaft and u-joint meet the differential yoke.
With that much lift and the longer radius arms (have some extra caster tilt built into them) and bigger C-bushings (might even have gone with 7° versions) they're tilting the pinion yoke down.
Luckily in this case you have the full-width front end, which also means it's a "high-pinion" or "reverse rotation" (misnomer, but in widespread use and makes half-sense anyway) Dana 44 so that gives you a better pinion angle to start with. But 5.5 inches can wreak havoc on lots of things.
You can see if it's causing any trouble at ride height by spinning the shaft by hand. With the hubs unlocked and the t-case in 2wd or neutral, you should feel it spinning pretty smoothly. If you feel it trying to bind slightly when it gets to certain points, then at some point you'll have to deal with that before doing much four-wheeling.
I forgot until just now that this high of a suspension lift is a good reason to keep the high-pinion front end. It was standard on full-size Fords and is stronger by at least 15% (ring and pinion gears riding on the correct gear tooth faces) and it keeps the pinion and caster angles better.
See? And you thought just a few questions and you'd be ready to to drive it into the sunset!
