ngsd
- Mar 2, 2019
- 2,559
I am a little stumped and could use some help. My old engine ran great but had a rod bearing starting to go so I swapped in another running engine I had in the shop. I used all of the old parts form the old engine including intake, carb, dist, fuel pump etc and basically the only thing that is different is the long block. It started and runs fine at idle and revs up but when you put it under load it just loses power and dies. It will start back up and seems like it is starving for fuel but runs and idles ok. I checked for vacuum leaks, timing, fuel pressure and all the things that are common sense but cant seem to locate it. Would a weak timing chain cause this? Just strange that it is just under load when I try to move.
