ngsd
- Mar 2, 2019
- 2,559
From experience, I have a 78 block someone must have swapped the cam, with the old firing order it started and idled, I had some backfire revving it up no load, and no power under load. Swapped 4 wires after 7 days of troubleshooting and its really a nice running engine.
Its similar issues to what you are saying, and with all the work you have done, you said you swapped dist. over? I'd look at plug wires and timing.
Thanks, I have the old distributor on the shelf, that may give a clue if the wires are reversed on it. I will take a look at that tonight. If it were that far off, would it still start easily, idle and rev smoothly?
